**CRYORIG is new and so is R1 cooler!**
Have done most of the testing on R1 Ultimate now. I have absolutely no complaints. The mount is a pleasure to install, cooler is beautiful and performs great. I'm not ready to say it's the best but it is definitely right up there.
I'm now building my Define R2 with the R1 Ultimate for a photo shoot.. LOL... My photo "skills" and "studio" are a joke, but will have some pics up hopefully tomorrow.
Than I'm back onto the test station for more testing of PH-TC14PE and Silver Arrow SB-E for comparison to R1 Ultimate. As soon as I start running these test I will be able to say just how good I think the R1 Ultimate is.. but until than I don't actually have confirmed comparisons.
Reason is my original testing was done with a GA-EX58-UD3R under i7 920 and that has changed to a GA-X58A-UD3R. Rest of components are the same... so my gut feeling is test results if not identical will be very close to what they were before.. probably less than +/-2c.. and as much as I would like to have tighter tolerances there are just too many variables in play. Results are probably only +/-1c, but to be safe I'm saying +/-2c.
Edit:
Vortez review.
Only compare air coolers here. Their CLC results are about 4-7c lower than they should be compared to their air cooler results. (room temp as base temperature and not the actual air temp going into cooler / radiator)
Conclusion
Most reading this will have never heard of CRYORIG before because they are newcomers to the cooling market but this, their debut is filled with great prospects.
Straight out the box, it’s clear to see CRYORIG are keen to make a lasting impression with R1 Ultimate. Packaging is attractive, well thought-out and the accessories bundle is laden with plenty of useful items – they’ve gone the extra mile.
CRYORIG’s R1 Ultimate has been engineered to an extremely high standard. Unlike many newer manufacturers it evokes the mature sensibilities of a veteran design, with none of the 'rough around the edges' feel which less well-appointed coolers exhibit.
Not only does R1 Ultimate ooze style on just about every level, but it actually works. Too often do we find companies introducing dressed up innovations as part of their feature-sets which fail to deliver but this is not so with CRYORIG’s new offering. During our stock, overclocked and passive tests this new cooler proved its worth and consistency, battling it out with some of the forerunners of the cooling league. Furthermore, the FX140 cooling fans needed only 1400RPM to achieve the results on the preceding pages whilst previously reviewed rival offerings required significantly more, thus bringing in unnecessary and unwanted noise.
http://www.vortez.net/articles_pages/cryorig_r1_ultimate_review,9.html
Here's a little more detail of what I mean about testing CLC and air coolers in cases without monitoring the air temperature going into cooler / radiator.
Vortez comparison of R1 Ultimate show:
  • Silver Arrow SB-E Extreme 2.6c cooler with 2x 2500rpm 130cfm fans
  • Silverstone HE01 is only 0.5c cooler with 2000rpm 171cfm fan
  • Dark Rock Pro 2 is 4.1c warmer,
  • NH-D14 SE2011 is 7.9c warmer.
Vortez only monitors room ambient instead of monitoring the temperature of air going into cooler / radiator. This skews their CLC reading to be 5-10c warmer. Not using cooler/radiator intake air temp when testing in a case means CLCs have definite advantage over air coolers because
  • they move more air through case (their fans are additional exhaust from case)
  • they dump all their own heated air outside of case
  • air coolers dump their heated air inside of case
  • raising the case air temperature
  • every degree warmer the air going into cooler/radiator is translates to about a degree warmer the CPU is
i7 3820 @4.75GHz
Temperature is delta.
H100 . . . . . . . . . 41c2500rpm . . . . . . . . . 55dBA 2x fans (stock)
SA SB-E . . . . . . . 42c1100rpm & 1300rpm. . 38dBA TY-150 & TY-141 (stock)
SA SB-E Extreme. . 34c2500rpm . . . . . . . . . 56dBA 2x TY-143 (stock)
http://www.youtube.com/watch?v=q6xrsuPwDbo
jump in to 3:40 for results.
That does not take into consideration the sound level of the coolers compared to CryOrig R1 Ultimate. ;)
The Vortez results are a bit dodgy imo. The passive tests would suggest that the heatsink isn't as efficient as a K2 or NH-D14 but with the fans, the Cryorig is significantly better. I can't see the fans, which operate at similar speeds to the Alpenfohn and Noctua fans, provide nearly 8C improvements on the latter. That's why I would be interested to see fan comparisons on those coolers, something that's been lacking in their reviews.
Maybe.
I'm not surprised the R12 does not perform as well passively. The radiators are 60% blocks by the fin end tabs. That is probably the reason perform as well passively but does with fans.
The first and second images in post 26 show what I mean. So does the last image in post 25
http://forums.overclockers.co.uk/showpost.php?p=25541019&postcount=26
We will see how R1 Ulitimate does with TY-147, TY-143 and PH-F140HP fans soon. ;)
I would rather use PH-F140HP_BK PWM but don't have any. :( Suppose I could try the PH-F140SP but they are not PWM either... and have 140mm mounting too.. just prefer using PWM fans full stop. :D
Maybe.
I see what you mean, but the K2's sides are more close up than that and still performs well passively so I don't think that's the issue. The radiator stacks are narrower than other dual tower coolers which would explain why it may not be as good passively but then the fans would have to be quite substantial to pull ahead in default configuration testing.
Is this wider than the k2? Im curious as my k2 despite being a very good cooler, it's a bit wide and blocks the top pcie slot on my mobo. Not an issue at the moment, but when i go sli again the only useable slot for my DX audio card is the top one above the primary gpu slot.
K2 = 146 x 154 x 160 (W x D xH) (with fans)
R1 = 140 x 130 x 168.3mm (with fans)
Edit:
I just measured mine at widest point is 141.29mm, the fan clips, and I could easily take them off and spring them to fit within the 140mm specified by CryOrig.
Pic below of current clearance with the k2 and a 120mm fan in the middle.
The pcie slot is just about visible to the left of the fan clip. I used this slot with no issue and sli in my previous z77 setup. However slot spacing on the formula is much closer.
Slot spacing is the same on all mobos mate.. or it wouldn't match the case slots. ;) The difference is the placement of CPU socket.. it's closer to the top slot. :D
I do see what you mean. in the picture. CryOrig R1 Ultimate would gain you 3mm.
Even the new Thermalright Silver Arrow IB-E with it's offset design is 67.82mm from PCI side to center of CPU Your K2 is 72mm (70mm without fan clips).. only 4.28 or 2.28mm less.
Ahh, should have said cpu socket. 3mm, wouldnt help tbh. The only other option is to get a pcie riser cable. Jamming the sound card in between the cards will be less than ideal as it will severely effect cooling of the top card. Ill be using non reference 780's in sli.
I can understand how frustrating CPU being so close to PCI slot. On my boards the first slot is blocked by the NB heatsink. I only use 1 video card. Only other card is audio so no issues for me.
Love the look of this cooler.
Need something for when I OC my i5 4670k. Will it fit into an antec 300?
g1.Sniper Z87 Mobo
Avexir Venom RAM.
Assuming Antec 300 has 170mm CPU clearance.
Cryorig R1 Ultimate is 168.3mm tall so no problem there.
But if Antec 300 has 170mm CPU clearance your RAM can be no taller than 36mm. to fit under the fan.. (probably with side cover touching fan and fan touching RAM)
178mm motherboard clearance
142mm fan & slot
36mm maximum RAM height in Antec 300
How tall is your Avexir Venom RAM?
Cryorig says:
Since the mounting height of the fans are adjustable between 177mm total height to 168mm at the lowest. Subtracting the total height of the fan itself 140mm and the difference of the CPU face and DIMM prop up distance, you get a space of
177-140+(8-2) = 43mm for the tallest configuration and 34mm for the lowest.
So RAM betwen 43mm~34mm will fit depending on your case.
Highest fan position allows 43mm RAM to fit (case must have 177mm CPU clearance)
  • Fan mounted as high as it will fit = 177mm + 8mm CPU = 185mm maximum height from motherboard.
  • 185mm with maximum height fan mounting
  • 142mm total fan & RAM (140mm fan + 2mm RAM slot = 142mm)
  • 43mm maximum RAM height with fan in highest position.
Lowest fan position allows 32mm RAM to fit (case must have 168.3mm CPU clearance)
  • Fan mounted as low as it will fit = 168mm + 8mm CPU = 176mm height from motherboard.
  • 176mm with minimum height fan mounting
  • 32mm maximum RAM height with fan in lowest position
Looking at the specs and technical data their doesn't look to be any difference between the Ultimate and the Universal other then the colour of the shroud, is their any other differences ?
I'm thinking of getting one, on the Cryorig it lists the various retailers for different countries, the one they list for the UK looks to be based in Germany even though they have a .co.uk address.
