Crysis 2 please help
mines running fine on a 5970+5870, getting somewhere around 90-120fps @ 1920x1200, although since i updated CAP to the mid-march ones i've got flickering water.
might go back to the one i had on before
Retail or Steam though?
I'm not sure how many fps I'm getting, but the game plays perfectly fine for me. Playing on extreme with 1920x1080 resolution. No noticable lag or flickering and I'm pretty far through the game.
Got it through Steam if that matters.
It's playable for me too through my Steam copy, i'm just not happy with the fact i have 30 FPS constant due to the fact it's not as demanding as the 1st Crysis, and i got around the same FPS on Crysis 1, as well as, i'm running a 5970&5870 in tri-fire.
Hi Chaps ! Im running a 5970 and got insane flickering with all Cataclysts. Its smooth now though after rename the exe to bioshock 2 !
Completed it on normal and loved the game ! Not sure why its getting such bad rep from some gamers. If you love sci fi action games, this is the one for you
does the r_MultiGPU=1 command not work anymore, because the first game doesn't use Multi GPU setups unless you tell it too as far as I know, when I played through it last time with my 4870X2 it said 'single GPU' in the console info display, then I enabled multi GPU through my custom settings and it ran sooo much better, weirdly enough more than double the framerate, not sure how that happened...? :confused: so yeah, try to make an autoexec for your Crysis II and put the line r_MultiGPU=1 in it, if the command is still there (which it should be because Cryengine3 is basically Cryengine2 more or less) then it should enable both your GPUs. ;)
@Racheluk, what CPU have you got and what speed is it running at?
A girl with dual 6990's and Eyefinity playing Crysis 2 :eek: I think you will be in my dreams tonight, lol :o
