“In UT3 hardware physics on my system does not have the little white in the box meaning its off, and I can gaurantee my fps never goes down to 12fps, its always up there 50+, I'm not lieing, I dont have hardware physics on, I dont think anyone has it on.”
You said 26fps average is unplayable and that if you turn hardware physics off you get a nice 59.7fps which is playable. Only if you’re getting 26fps with hardware physics you’re getting 12fps without hardware physics.
There is no way you turn hardware physics off and go from 26fps to 50+fps on the same map.
”You're trying to say no mater what UT3 has low fps for all?”
No, I am saying hardware physics is always faster then the CPU.
http://img.photobucket.com/albums/v319/thehub/ut3hp.jpg
Thats how I have it set, and its always over 40fps, perhaps physics is off, because its smooth and I would never buy a physx card for UT3 or any game since the difference is minimal and not worth the hit in performance I would rather have no physics untill something better comes along that does the job fine.
