Hey Guy's
I have started a new project (no name) in the x71 case. I am going to be modding the front of the case and adding temper glass. It will have a dual loop two pumps two Res and two 360 rads, I am looking at replacing the motherboard tray and add my own plus a few little surprise a long the way. Also going to we extending and sleeving all cables.
Components.
CPU: i7 4770K overclock to 4.6
RAM: Corsair vengeance Ram 16gb
GPU: Zotec 980ti
PSU: Corsair ax 860
WATERBLOCKS: EK
2x Pump: EK d5
2x RAD: EK 360
FANS: 7x 120 Riing 12 thermaltake RGB
FANS: 3x 140 Riing 14 thermaltake RGB
FITTINGS : Thermaltake pacific petg 16mm compression.
FITTINGS : 3x EK pass through
HARD TUBE: Thermaltake Petg 16mm
Was not sure if I should use 2x 140 or 3x 120 fans still not sure what do you think?
I like to draw out what I want to do and I took size for new motherboard tray.
I did draw up some designs for new air intakes then got them laser cut. I had to cut some of the front case for them to fit. These are removable not sure if I am going to leave them clear or paint them.
This weekend I am hoping to drill out the rivets and start the motherboard tray. Sleeve the pumps and front panel connectors.
Thanks for checking out my mod any question or feedback let me know below.
Components.
GPU: Zotec 980ti
PSU: Corsair ax 860
WATERBLOCKS: EK
2x Pump: EK d5
2x RAD: EK 360
![16997995_1301876643236636_1248765189986096513_n_zps9q8jmnnd.jpg](http://i1160.photobucket.com/albums/q494/Richard_Ord/X71%20BUILD/16997995_1301876643236636_1248765189986096513_n_zps9q8jmnnd.jpg)
![16998927_1301876646569969_7780935247742659796_n_zps1o4rjho1.jpg](http://i1160.photobucket.com/albums/q494/Richard_Ord/X71%20BUILD/16998927_1301876646569969_7780935247742659796_n_zps1o4rjho1.jpg)
![16684128_1301876579903309_1698262511755813451_n%201_zpsjn1ceuof.jpg](http://i1160.photobucket.com/albums/q494/Richard_Ord/X71%20BUILD/16684128_1301876579903309_1698262511755813451_n%201_zpsjn1ceuof.jpg)
![16939634_1301876586569975_4795992118718561829_n_zpsatsh1hnk.jpg](http://i1160.photobucket.com/albums/q494/Richard_Ord/X71%20BUILD/16939634_1301876586569975_4795992118718561829_n_zpsatsh1hnk.jpg)
![16806870_1301876576569976_4763509986663472095_n_zpst4o14sa6.jpg](http://i1160.photobucket.com/albums/q494/Richard_Ord/X71%20BUILD/16806870_1301876576569976_4763509986663472095_n_zpst4o14sa6.jpg)
![17021930_1301876519903315_1843705610719218260_n_zpsj75oqvqk.jpg](http://i1160.photobucket.com/albums/q494/Richard_Ord/X71%20BUILD/17021930_1301876519903315_1843705610719218260_n_zpsj75oqvqk.jpg)
![16997771_1301876526569981_791118452331752868_n_zpsi103ejg9.jpg](http://i1160.photobucket.com/albums/q494/Richard_Ord/X71%20BUILD/16997771_1301876526569981_791118452331752868_n_zpsi103ejg9.jpg)
![16939554_1301876523236648_1514971013046667225_n_zps44qfcfcm.jpg](http://i1160.photobucket.com/albums/q494/Richard_Ord/X71%20BUILD/16939554_1301876523236648_1514971013046667225_n_zps44qfcfcm.jpg)
