Hey Guy's,
I am back with a little update, feels like I have been here before.
I took the case apart and fully strip it down to bear shell to replace the snapped motherboard tray. It felt like it took me days to de-pin all the cables that ran through the motherboard tray to the motherboard. Once I did this I tape up the perplex and mark all the holes for the motherboard standoff once I did this I tap the holes and added the standoffs.
I put the res in the same place as before but I want to change the hole for the pass through for the intake which I think will look a lot cleaner, I don't like to use a lot of fitting if I don't need to. When it came to do all the holes for my pass through hole I could not find my 20mm drill bit, so I pop on amazon and had it next day, it put me back one day, as I don't like to paint until all holes are made. While I was waiting for the drill bit I replace all the logos on the case fans to AML logo. Once I got the drill bit a few minutes later all the holes were done and it was time to paint. The paint came out great, I fitted motherboard tray back in to the case add the res, motherboard and GPU. I still need to pass all the cables back through and add the the pass through fittings.
With me taken the full case apart I am going re do the basement and make it look a little bit nicer. The build it self, I would say is nearly done and like I said in my last post that it will never be 100% complete, but I am very happy with the way it looks, just need to make sure the hard tubing is on point.
I have added photos below as always if you have any feedback or any question please post below.
Untitled by
Richard Ord, on Flickr
Untitled by
Untitled by
Untitled by
Untitled by
Untitled by
Untitled by
Untitled by
Untitled by
Untitled by
Untitled by
