Custom Loop Order
Double check you can use that Bridge with the Csq blocks i sent you, otherwise it wont fit.
Hard tubing, soft tubing?
Ahh right - I do need a bridge as it would be easier than using fittings to link 2 cards.
Snips how much rad space are you planning on getting?
I only have space for 2x 240mm which should be fine!
Looking at this atm:
YOUR BASKET
1 x Hardware Labs Black ICE Radiator GTX-Lite 240 £29.99
1 x EK Water Blocks EK-FC Terminal DUAL Parallel £13.99
1 x XSPC HighFlex Hose 3/8" ID, 5/8" OD, 16/10mm, 2m, Black £6.49
1 x XSPC LCD Temperature Sensor (Red) V2 + G1/4" Plug Sensor £5.99
2 x Mayhems Ultra Pure H2O Watercooling Fluid 1L £4.99 (£9.98)
4 x EK Water Blocks EK-ACF Fitting 10/16mm - Nickel £3.79 (£15.16)
Total : £91.21 (includes shipping : £8.00).
