[DOD]Asprilla;24680772 said:Do you feel that about other road users as well?
Absolutely, for example tractors/slow moving vehicles that have a queue behind them but don't pull in at a reasonable opportunity to let traffic past etc.
Depends if your light faces forwards, backwards and to the sides as well.
If a driver can't see me when I'm cycling and wearing normal clothing then they shouldn't be driving and they should go and get an eyesight test.
And I've a 110 lumen rear light - hi-vis is insignificant compared to that.
And how many of those have you seen on the road?
[DOD]Asprilla;24680832 said:Loads. I've got a couple on my waterproof rucksack and another on the back of my carradice bag. Platypus has them on the seatsays on his bikes. They are a very popular light.
Lights are only really visible front and back. High vis makes you visible side on.
Ultimately, I go back to this point:
It's a two way street, neither group should expect the other to be making all the allowances for their preferred road use with no consideration in return.
Cyclists would prefer I drive in a manner that makes their cycling a more pleasant and safe experience.
As a motorist, I would prefer cyclists ride in a manner that makes my driving a more pleasant and safe experience.
Be this overtaking space, riding single file, wearing hi-vis, not cutting cyclists up on left turns etc. I don't understand why the idea that there should be give and take from both parties doesn't seem to be acceptable to some and they feel the other group should make all/more of the concessions to accommodate them.
As a car driver (which nearly all cyclists will also be) you need to be aware that in an incident with a cyclist they are going to come off far worse than you. Even if you think they're being ******** you should give them space and look out for them because you don't want someone to end up seriously injured or dead.
So what are you saying? You won't change the way you personally drive until you consider that cyclists as a group have compromised too? I hope not, but that's how it sounds.
P.S. I don't agree that 'nearly all' cyclists are valid UK driving license holders either.
83% apparently.
I know for a fact that everybody I know with a cycle also has a car.
Yes cyclists are always wrong
I drive with respect for cyclists. It would be nice if that was met with a similar respect, rather than arrogance and an attitude of 'picking and choosing' which bits of the highway code they think should apply to themselves and others.
[Citation needed]
A new THINK! campaign, THINK CYCLIST, calls on drivers and cyclists to stay safe this autumn by looking out for each other – pointing out that drivers and cyclists have more in common than is often realised. With 80% of cyclists holding a driving licence, and 1 in 5 drivers cycling at least once a month, they are often the same people.
