I'm currently full steam on NFS and it's pulling just 264W from the wall![]()
It's now 380W from the wall with everything on Asteroids (you watching MGP
Vcore has gone up from when it was on NFS.
Hey dont knock the idea of them hanging out the window, north facing and a chilly wind and i get 10oC lower temps then if it was inside the room even more in winter
wow it looks good http://www.thermaltake.com/content.aspx?id=6256
Agree, it does look good, might be a bit pricey though
I see OcUK have removed the other Thermaltake case they had from the site.
I'm also surprised OcUK are taking so long to add their own Window Wedge (©PDW 2015) AIO cooler to their product list![]()
It's now 380W from the wall with everything on Asteroids (you watching MGP), still pleased with that, it has pretty much the same processing power of all my other rigs combined (3 x 3770K & 2700K).
Hanluc how much memory are you running? I managed blk to 105 and been stable. When you said you were tempted to get another one did you mean dual cpu board? I wonder how much the 22 core will be??
I can't see what you've got running as your machines are hidden, but i guess it's a mobile phone or something judging by your recent productionpfft, that's barely worth opening one eye .....
Just thought I'd see what's what !Hey PDW, I noticed you are having a dabble on GIMPs
I get my trial factoring assignments from http://www.gpu72.com then enter the results into the GIMPs site as normal. They have much larger exponents to factor, either Lucas-Lehmer or Double check, the default ones at the GIMPs site are small and complete too quickly, unless you change the end exponent yourself, which is a lot of faffing about.
290/290x rock on that BTW and you can crank the clocks up really high.
Thanks, I'll have a look at gpu77 when the current lot have been done.
For fun, and to see what it was like for folks in olden days, I ran the first assignment on the 8600 GTS before swapping over to the 750Ti. It took about 13 hours to get 4 points
The 750Ti is a lot faster and even though it is doing the sieving on the gpu running DPAD at the same time slows it down by around about a third. It only takes about 50% power and runs cool in its favour. Not sure how much of a problem being a 1.0 slot is for it
Despite all these problems I stormed past dekez to take 5th yesterday and should make 4th after tonight's upload
Will unleash the 290Xs when they have finished Moo![]()
I ran without for a while and immediately after starting DPAD it dropped and stayed there.I'm surprised running DPAD effects production, the newest clients are supposed to use very little CPU resource. Talking of cards from the olden days Nvidia 5 series cards are excellent on GIMPs, they out produce many of the newer series.
Performance chart: http://www.mersenne.ca/mfaktc.php
The GTX 750 Ti is rated at just 137 Ghz days there, my 570s can do over 400, and my 290s overclocked @1125 (non x) do 735 Ghz days.
Remember you need a different client for AMD, mfakto.
