Decent Pen?
3 Dec 2004
Hello all,
This will probably sound like a sad question but im after a decent pen :)
Fed up of relying and being let down by cr@ppie Bics.
Pen will not be used to write huge ammounts - stuff like notes/signing.
Im clueless on this subject so what are the better makes to look out for? Also how exactly does a foutain and biro differ?
Have a £50 budget :)
Thanks,
Blimey, I find the good old Bic biro does the job. I guess if you want to get all fancy get a Parker of some type?
i have a cross pen, and really like it.
Personally i find biros make my writing look terrible, and i find a fountain pen much easier to use, though for convenience i use a biro a lot of the time these days.
Look for Pilot pens, £50 will get you a fine range, best pens I've ever used.
panthro said:
Pilot are nice, I use them at work. My hand-writing is terrible, but the Pilots manage to make it readable :)
Me too. I hate using normal ballpoints, and it shows, but Pilots seem to neaten things up considerably.
I can't for the life of me write with a bic/rollerball.
I use £8 Parkers from WHSmiths, they're weighty enough and fine for a pen I suppose :confused:
Just get a fountain pen and see if you like it.
Pilot pens without a doubt.
Uk contact details;
The Pilot Pen Company (U.K.) Ltd.
4 Dukes Meadow
Bourne End
Buckinghamshire SL8 5XF
Tel.: 0044-1628-522805
Fax.: 0044-1628 851416
contact us
www.pilotpen.co.uk
