Why bother testing it on fuel it isn't going to be run on?Vertigo1 said:We're all assuming it was actually running on diesel. Is it possible they were using some alternative fuel in it, which could burn fast enough to make 7500rpm possible?
Jonnycoupe said:Its probably a fatigue test for some components like the valves and conrods?
merlin said:I think Simon might be on holiday as I've not seen him post for a while.
Stonedofmoo said:Sure I saw a post of his yesterday!
I gotta agree with Fox, seems to be to get that far at those revs is amazing. Surely even the modern diesels don't go much beyond 5500rpm.
I wonder if they use special engine oil for such a test, must run a big fuel tank!![]()
Jonnycoupe said:Is it a full engine test or a single cylinder prototype.
I thought the same as you though and thought the limiting factor was the burn time of diesel itself.merlin said:I think Simon might be on holiday as I've not seen him post for a while.
hilly said:Give him a call mate, he's definately the one to speak too.
Stonedofmoo said:Perhaps they'll use a VVT system and using this it will get the revs up to a normal engines level lol
merlin said:His brother is here & talking sense, don't need Simon now.![]()
hilly said:You trying to say Simon doesn't talk sense? .... good point. Carry on![]()
Jonnycoupe said:He said he beat you on Pro Evo.![]()
Dogbreath said:If by some miracle they could get it to run at that speed, with the heavy internals I would have expected fatigue failures more quickly than 1200 hours.
