Butters said:that and the fact that the pressure from common rail systems is enough to blow the skin off your finger down to the bone shows its more than capable at fueling.
Butters said:Surely this all depends if the engine was on a dyno or actually running through a gearbox. without a GB attached a diesel engine on the bench will run any revs you want it to. Most modern day diesels will bench at well over 7.5k rpm. Its not a case of diesel not being able to be burned quick enough as long as its getting the air it will burn all day long, that and the fact that the pressure from common rail systems is enough to blow the skin off your finger down to the bone shows its more than capable at fueling.
Simon said:Durability testing is about seeing how long the engine last and monitoring parameters.
Hardly about going well past the design spec of an engine.
Diesel engne speeds are limited by the combustion time of diesel aswell as the heavy parts and I'd be pretty sure the valvetrain would struggle at 2500rpm over the max engine speed.
Hard to comment without context though. My durability test is 800hrs at full load 4000rpm on a 'normal' 2.0D engine.
Simon said:I'd be pretty sure the valvetrain would struggle at 2500rpm over the max engine speed.
merlin said:Maybe that was the whole point of doing 7,500rpm?
To purposely see how long the top end could cling on to dear life.
Jonnycoupe said:If a conrod failed it would be a perfectly good reason for a fatigue test.
1200 hrs at 7500 equivalent to i dunno 4000 hrs at normal rpm limit but the test is complete way faster.
guess they were wrong thenmerlin said:They said it was "unacceptable" the engine did not hit 1200 hours.
Their engineers have calculated that 1200 hours = 100,000 miles.
I'm sure I read that the piezo injectors in the VAG diesels use five separate fuel injections per cycle. In a four pot at 4500rpm that'd be 750 fuel injections per second if my maths is rightButters said:The problem is that your injection window gets shorter as the engine speed increases.
Perhaps they are testing Piezo Injection technology
