....really. I'm not so sure
Post your two card score in the same spot? You really need to match my cpu threads for a fair test though.
Cripple your system to make it fair Frosty for goodness sake.
Lol. I don''t care whether he does or not. Just saying if you're both so keen to compare to my results then to make it accurate you'd need to have the same or similar cpu settings.
He's only at 4ghz though whilst you're 5 or something aren't you Matt?
I honestly feel that your DX frames are very low. I seem to remember your fps being much higher in the BF4 bench thread on <14.1 drivers but maybe they have never been that good and as you say, you can now run the CPU at stock to get the same frames as what it gets overclocked.
It doesn't matter and if you are happy, that is all that counts but to me, DX isn't as bad as is being made out but sure, it could do with an overhaul.
Just out of interest, have you run with your CPU at stock and Mantle yet? I would be interested to see if it does relieve the bottleneck.
Finally, a kick up the bottom is what they need but if they make it exclusive to Windows 8.
Then there will be hell to pay.
 a nice lightweight gaming OS from MS would be great but until Steam or another Linux OS starts getting popular I doubt they will do it.
 a nice lightweight gaming OS from MS would be great but until Steam or another Linux OS starts getting popular I doubt they will do it.I honestly feel that your DX frames are very low. I seem to remember your fps being much higher in the BF4 bench thread on <14.1 drivers but maybe they have never been that good and as you say, you can now run the CPU at stock to get the same frames as what it gets overclocked.
If you look back at what i benched in that thread on 13.12, it was largely 32 man TDM. This was benched on a 64 man server with the cpu playing a much bigger part.
ok I've crippled CPU and only two cards running, all stock. back in 5
Lol. I never used 14.1 ^^ It wouldn't run on my system. It locked up when i tried to use crossfire on BF4. Are you making this up Greg? I've never posted any results on 14.1 apart from one single card run in the Mantle bench thread.
290 and a titan are about even in performance on dx when using the same cpu as showed by every tech site out there when benching bf4. Similar to the 290X and the 780TI. My directx results would be higher if i had a 6 core cpu. I'm bottlenecking my 290's, even with my cpu at 4.8ghz and my gpus at stock clocks.
I've not yet, but i will do at some point.
Gregster..got a question for you regarding the asus VG278HE. Will start a thread in monitors section as cant send you a message.
there you are Matt. All stock, two card run and CPU de-limbed and crippled.
2 cores running (as selected in BIOS)
Any other areas worth screening?
There will always be a reason it isn't fair Frosty. Don't waste your time bud.
