I Know what you mean about the mobo tray, really makes the job a breeze, its not a necessity but puts a smile on your face as its just so easy.Keylow said:Yeah. I don't think I could live without a mobo tray now ive used one for example. Id just like to have one just to say I have one though, since its probably one of the best all around cases ever.
Mark A said:I Know what you mean about the mobo tray, really makes the job a breeze, its not a necessity but puts a smile on your face as its just so easy.
Mark
1) Is it fan noise or does it go away when you press the side panels in?
2) Unplug the power for your raptors and boot up, is it now better? (plug back in after)
3) Unplug the Ambers and see if that stops the noise?
Yewen said:
It is removable on my PC-7.PinkFloyd said:Yeh you can do that fine
95% sure the bottom bay is removable
Yewen said:Ok, simple one to start list to start with.
Three things I would start with, all are VERY easy to sort out.
