Interesting? look forward to your resultsBito said:Currently testing for lowest vcore at 3.0ghz.....down to 1.192v so far....Gromacs and cpu stress Orthos stable.....
Big.Wayne said:Interesting? look forward to your results
What stepping do you have there? I look forward to the resultsBito said:Currently testing for lowest vcore at 3.0ghz.....down to 1.192v so far....Gromacs and cpu stress Orthos stable.....will continue going downwards with volts and report back with pics
JeffyB said:What stepping do you have there? I look forward to the results
JeffyB said:Its a L629B, needs about 1.4v for 3.6ghz i havn't managed to get it 12 hour orthos stable yet though.
In bios.Cob said:1.4v in BIOS or in Windows?
Good stuff, where are the screenies?Bito said:Mine runs at 1.4vcore for 3.6Ghz Orthos/Gaming stable.
Big.Wayne said:Good stuff, where are the screenies?
The vdroop is the most annoying thing, makes getting stable overclocks a lot harderBito said:Best to do the pencil mod. to your boards to stop the vdroop being a factor.
I love the load temps with undervolted cpu'sBito said:LOL
Here's one from earlier.....
Now looking good so far for 3.0Ghz at 1.184vcore
That question can be interpretted in different ways, I take it you mean can the entry level chips overclock to a level which is faster than the 6700 at stock? if so the answer is yes they can!Yella Fella said:does the lower 6300/6400 and the 6600 overclock higher than 6700 at standard? im a bit new to all this duo core malarky
