Recently purchased an LG OLED C2 Evo and I'm in the market for a decent soundbar with Dolby Atmos and have been looking at the Sonos Beam Gen 2, any thoughts?
The Beam Gen 2 doesn't have any upfiring speakers, therefore I wouldn't consider it a proper Atmos capable soundbar.
What's your budget?
If you can spend on AVR and speakers those will offer far higher sound quality and proper atmos steering
Did consider this but I think a decent 'ish' soundbar would be more than ample for our needs.
Don't get a crappy little 5.1 system. Way too much hassle and fiddling needed, plus they are not that good compared to the below soundbars.Recently purchased an LG OLED C2 Evo and I'm in the market for a decent soundbar with Dolby Atmos and have been looking at the Sonos Beam Gen 2, any thoughts?
Also, a Sonos beam and sub isn't that great either, mostly just overpriced for what it is.
Just get a Samsung Q930b, or if you're feeling more flush a Q990b.
For reference, I've just sold up one hell of a 7.2 system due to how good the Q990b was. Wireless sub, wireless rear speakers and an ATMOS sound bubble that a normal AV setup cannot get near unless you spend 5-10x the cost.
You should go educate yourself, gain some experience and listen to some decent systems rather than posting useless unhelpful drivel.Haha
You should write stand up comedyy
It's deja vu with these threads, people ask for a simple plug and play soundbar and it's always the same person responding with "buy an AVR setup" instead...
See what the likes of Richer Sounds have in your budget and check out rtings reviews and comparisons to see which best meets the criteria you feel is most important to you.
They give the Sonos Beam Gen 2 a fairly average write up.
Around £400/£450. Considering the Bose Smart Soundbar 600 at the moment.
