dont understand output...help
15 Nov 2009
Fife, scotland
Hi guys,
firstly happy new year, hope you are all well and not to hung over :eek:
i have x2 agility 3 60Gb drives in a raid 0 for my C:, i have these since the older days of SSD'd. i am planning on upgrading soon however for now thats what i have.
i have run CrystalDisk and im getting the output below..i'll be honest i have no feking idea whats up....
can anyone offer advice?
not really.....was just playing around to be honest with some diag tools.
the only thing i thought it could have been was it was 29% fragmented but i thought that didnt matter really with SSD'd?
i have since defragged it anyway. not really having speed issues....not that i have anything to compare it to though :D
you don't need to run disk defrag on SSD's and from my understanding it shouldn't be ran on SSD's as its a HHD tool.
it movies files for quicker access for HDDs but being a SSD you don't need it. are both the drives in a raid setup or just 2 x standard SSD's?
here are screen shots if my 2 SSD's, not in raid
2Cs9Ru6CJ3rUjafH
and
l8mUiCdHNeYhAYCM
Is it because it can't read the temperature as it's a RAID device?
im thinking this is what the issue is tbh, these are x2 OCZ Agility 3 60g versions running as one.
im using speccy and it cant even read the SMART function as its disabled in a raid i believe, maybe im just panicking :D
if its setup using raid then im guessing this is why it cannot read the drives properly as windows will see them as 1 drive.
when I raided my two ssd's the magician software cant even find the drives as it appears as a intel drive.
unless your having issues I wouldn't worry too much about it just to be on the safe side don't keep anything you can restore or afford to loose
I have a red error message if I use the WD diagnostics on my MX100,can't remember what one it fails on but the SSD never passes SMART tests although it's been working fine since it was fitted must be 2 months ago now.
