- 1 Dec 2015
Well, seems im to be a father for a second time which leads to the bad news of having to move my desk out of the 2nd bedroom were the first spawn sleeps to make way next year.
Currently rocking a TJ07 and in a 2 bedroom 62m squared house, space is tight and so is the cash- story of everyone really
so the i7 860 bought from Launch date in a Second hand ROG 3 Formula with 16GB of DDR3 is moving into a small home to fit on my wife's desk.
Find a small case without having to buy a second hand p55 mATX was a bit of a mission, until I saw a deal on the Jonsbo UMX4- b grade!!! Having used the UMX3 for clients I knew the quality is that of the Silverstone.
Coming in at 37.97 Litres I believe its one of the smallest Volume ATX cases out there, the TJ07 was 69.6 Litres.
Plans are to keep it quiet so will be sticking with water.
beQuiet Silent Loop 240 to cool the CPU with fans being changed to SilentWings 3, this will be set up top to Extract with the rear set to intake, full speed being a PureWing 120
Strix 480 to replace the GTX 960 4GB since i Have a 1440p screen, and so down the wife. Will be using the Strix ability to control PWM fans to drive the bottom fans, which will be SilentWing 2's.
Hoping the fac AMD handle's DX12 better will help off load the old i7 860 running at 4.6Ghz.
Keep seeing all these bench marks of DX12 vs 11 being use don Skylakes and Devils...which is great and all but most machines on steam are rocking a lot older CPUs, so I see this as a real test for DX12!
Might go with a GTX 1060, depends- either option will be watercooled with an alpha block, thinking of using EKWB Predator 240 at the bottom ( in the wrong orientation) to drive the GPU in its own loop, whilst using the STRIX fan controller to control the pump and fan speed
PSU is a B-grade Corsair AX 750 Plat so if I go 480 will crossfire it later (im lucky, i get it at trade price so second reason why i'll use the Strix)
current old dog
Thermochill pa120.4 in the bottom
classic icon!
current old dog
classic icon!
