Permabanned
- 28 Dec 2009
- london
No :/
Might be best if you are looking to get in to it to look in the multirotar thread in GD
I have a DJI F450 kit with Naza V2 GPS flight controller, that came to £280, then FrSky Taranis radio gear came to £180, FPV gear probably another 150-200 +, depending on what you buy
However you can build them on a more strict budget, or you can spend more (thousand(s)
You can build your model from the parts, or you can buy these pre-built ones, which tend to work out more expensive
What sort of distance can you get on that? and then you have the camera as well. All adds up.
this one looks good
http://www.parrot.com/usa/products/bebop-drone/
maybe a little matchbox car. marbles.
