- 18 Oct 2005
I don't own a PSP anymore, but I've heard using the largish memory stick as a data cache can improve battery life.
GSXRMovistar said:I dunno, all that added up comes to approx 7.3 hours
2.9 Hours (50* 3.5 mins MP3s)
0.9 Hours (2 * 25 mins FT)
1.5 Hours (90 mins GTA)
2.0 Hours (Sin City)
Not sure about the 15% batt left afterwards but I'd say the above is possible. As mentioned above, there are ways to extend the battery life but they can't be discussed here.
I was assuming that Raikiri was playing films off memory stick (ripped from his own DVDs). Using a mechanical drive will always use more power than accessing data off chip.kreeeee said:UMD movies absolutely kill my battery!
GSXRMovistar said:Using a mechanical drive will always use more power than accessing data off chip.
GSXRMovistar said:I was assuming that Raikiri was playing films off memory stick (ripped from his own DVDs). Using a mechanical drive will always use more power than accessing data off chip.
Firstly no need for the stupid sarcastic commentskreeeee said:You don't say...
Errr I wasn't, I was only trying to back you up as others were calling you a liar.Raikir said:but it isnt as bad as you are making out. Only thing i can think of is you have an earlier model with an inferior battery
