Dying Light GPU and CPU test
what is the app that gives the fps aswell as the ram usage CPU1,2 etc usage? Only one I knew of was Fraps but then its been ages since I messed with this stuff :)
Afterburner with the HWiNFO64 Program..........
The above is with my GTX 970 at 1440p
Is there any comparisons between the release and the newest patch, performance wise? I've heard that thet patch literally improved the game by 4-5 FPS...
id say cpu performance a lot more smooth, gpu nada!
maybe there will be some driver updates soon!? i duno ><
Going from 8 to 16GB, prior to the patch, made those disappear in my case. Still some some minor 1 second freeze at time when a zombie bites me or the scene goes to a conversation with an NPC and during gameplay just once in a while - nothing severe like that.
Thanks. I've ordered another 4GB to take me up to 12GB. Not just because of Dyling Light but I also saw Lords of the Fallen was using a ton of ram, and I get the feeling this might become common with ps4/xbone ports.
Should be my last upgrade for a few years.
As for the patch, definitely seeing more even CPU loads now. None of the cores are hitting 100%.
Another question I have is I was playing dying light and all of a sudden the fps started jumping high to low and pausing. I loaded battlefield 4 which is always perfect and that was doing the same. I restarted the system and then it was fine. Anyone know what the problem could have been
Thanks
Played this yesterday at 1440p144hz, with gsync and 980SLI.
Game is a stuttery mess.
I get over 100fps most of the time but there is still stutter. And, the chromatic aberration is horrible. Actually puts me off the game entirely and isn't there in the PS4 version.
I tried some comparative screenshots. http://imgur.com/a/w9s72
Those trees in the distance are crap, the water is flat, and chromatic aberration is making my eyes hurt. I can't play this game due to the aberration and forced blur.
So the chromatic aberration cant be turned off ?
Because if the patches fix the other issues the game would be back on my wish list but if the chromatic aberration cant be turned off in game or inf files then no way as it hurts my eyes as well.
Runs fairly smooth tbh, on lowered details.
The second area was stuttering to begin with then calmed down.
Overall, decent little game. No idea what it looks like with maxed settings. Don't care for it.
