- 4 Nov 2006
- Yorkshire
Met him a few times in a few clubs in Leeds, he is a complete ****** in person and thinks he is god's gift to humanity.
never really liked him. does anyone believe this stuff after a certain age
http://www.videojug.com/film/how-to-throw-a-card-through-a-window
apparently he wasn't working alone
Thanks but doesn't explain a few things.
1. He didn;t know which pub we would be in and he had travelled 200 miles so was not expecting to do the trick until I kept on and on at him (although he might expect that I would)
2. There is no way the card was already there. This was behind a one foot square window on a door before he threw the cards at the glass.
3. The card was signed by somebody.
I agree that there is a "trick" to it and it's easy to get people to pick the card you want them to if you're good enough. I just don;t get how the hell it's pulled off with a signed card in a strange pub. I mean, he only does magic as a hobby and is a sales rep. That's a hell of a lot of effort just to impress a dozen people in a village pub tro bring along an aclompice.
I could write essays about this guy. He's a good illusionist and is great with card tricks. However i don't like magicians who pay people to act / get in on the trick.
Obviously he isn't actually capable of performing real magic so yes the events are "staged".
But I can't believe that he achieves most of his magic by using plants. If that was the case then as I said before what's the point? Anyone can do that.
I think it's a case of you can't work out how he did it so you default to accusing him of using stooges.
Does he though?
Only it's very easy for someone to see a trick and because they can't work it out just assume the spectators must have been in on it (easiest way to explain pretty much any trick isn't it).
For example, I've heard people say it about Derren Brown and his stage shows. I know how pretty much every one of Derren's theater tricks are done and none require the audience member to be in on it, he states he doesn't uses stooges and yet people (frustrated by the fact they can't work it out) will still claim he does.*
* Although I suspect 5UB and myself could have an interesting debate on what constitutes a stooge, ergo people that are 'hypnotised' etc etc....
Card through the window is a good effect if done correctly. If you are good you can do it inside a moving train.![]()
Problem with that is your memory of what happened and what ACTUALLY happened are likely to be different.
I bring you back to him bench pressing 150KG.
That's all you need to know that he's 100% using stooges in at least some of his tricks because he 100% DID NOT bench press 150KG.
Spill the beans then 5UB or atleast point to a video explaining it![]()
Of course he didn't, it's a magic trick. He can't actually pull Polos throws his neck in reality either.
But that doesn't necessarily mean a stooge (the black guy who goes first) was needed for it. There are mechanical ways that effect could have been created whereby the black guy really was lifting a 'heavier' weight that when Dynamo tried it. Plenty of Magicians do a light/heavy routine whereby they'll lift a box easily and the spectator tries it and can't and that isn't done using stooges.
The automatic "it must be stooged" explanation to a magic trick reminds me of the "God must have done it" argument when someone doesn't know the science behind something.
Is that the one who faked the entire scene with him benching some stupid amount of weight?
If it's not arranged beforehand, I'm not sure you could class them as a stooge?
Do you realise what you posted?
The point is that it wasn't 150KG and it's easy enough to see that.
Of course, theirs an irony, but theirs recreating an illusion, then using stooges. on an edited tv programme.
No your point was he was using stooges.
What you've typed above is just silly and sounds like you don't understand the nature of a magic trick. He was doing an illusion, not an actual demonstration of his amazing strength.
Prove he's using stooges.
I'm not saying he doesn't, I just haven't seen anything to suggest he does. Of course he has assistants etc but that isn't a stooge. A stooge is specifically someone who is pretending to be THE spectator the trick is being done on, but in reality isn't.
