I'd say that's about right! My old 2160 would do 3.6ghz which is quite high (and rare) but most successfully clock to 3.2ghz without much trouble.
Is it to replace the 6320 in your sig or is it for another PC?
gt
0.0 my mates one only reached 2.8GHz lol
The E2160 has a 9x multiplier so you won't need FSB's over 400 usually, unless you have a golden chip which can do 3.6ghz+. Of course you can still go with 1066mhz memory, but if it was my choice I'd save the cash and get an E2180/E2200 instead.Perhaps it has something to do with Memory and Motherboard?
I was thinking of giving him:
Abit IP35
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Thermalright Ultima-90i CPU Cooler
And the E2160
(Only most important parts listed!)
Edit: Is it better paired with 1000Mhz+ memory?
Higher multi. So it may be "easier" to clock than e2160.
Which ever you go for should do 3ghz+ unless you get unlucky.
pc2-6400 is all you need
Yep, my E2160 does 3.2Ghz at 1.5v, Orthos was kept under 60ºC too
Completely agree! My e2160 @ 3.6ghz easily matched any of the 3x e6600's i've had. Wonderful chips that can take a real beating too!!!I'm running my E2180 at 3.4 with 1.35 volts prime stable. Very impressed with the E2XXX considering the price.
I would have gone for an e2xxx chip had I found one at a decent price. However, I thought the e4500 was worth the £5 premium, as at the same clock speed it should give higher minimum frame rates in games.
