I assume these chips will work in my DS4? Maybe with a BIOS update?
MeatLoaf said:I assume these chips will work in my DS4? Maybe with a BIOS update?
MeatLoaf said:Hmm, i was considering switching my E6300 for an E6400 next month as im hoping its higher multi will get me to 3.4 - 3.6Ghz
Will the E6420 have the same 8x multiplier?
Robbie G said:Journey - you are an idiot. Read Nathan's [useful] post. Conroes do not all have 4Mb cache.
Big.Wayne said:It looks like the new 6320/6420 are actually [b2] Conroe chips, i.e take an e6600 with good working 4Mb cache and just set the default multi lower (in this case x7 and x8).
INTEL already have an outlet for Conroe chips that are produced with faulty cache, they just disable half the cache and sell them as e6300/e6400, so it looks like they found a way to sell of Conroe chips that have been produced with a good 4Mb cache but maybe the core isn't up to running e6600/e6700 speeds, so they just drop the default multi and rebrand them as 6320/6420.
Am I right? or am I right?
Ok thats a valid point but I'm not so sure about that. In theory what you are saying is that INTEL are taking a perfectly good e6600 (or e6700?) and hamstringing (<is that a real word?) them? Not impossible but armed with that knowledge why would anyone now buy an e6600?Minstadave said:This is where us overclockers benefit
Big.Wayne said:Ok thats a valid point but I'm not so sure about that. In theory what you are saying is that INTEL are taking a perfectly good e6600 (or e6700?) and hamstringing (<is that a real word?) them? Not impossible but armed with that knowledge why would anyone now buy an e6600?
Yes I remember, I had an XP2500+ in Aug 2003 nice chip at XP3200+ speeds. On the whole I'm aware of the speed binning process but I don't just assume thats the case every time a chip manufacturer releases something new, also figure in the soon to be released e6650 and e6750, are these just gonna be overclocked e6320/e6420's (simply running 333MHz-FSB instead of 266MHz-FSB)or are the e6320/e6420 just underclocked e6650/e6750's?Minstadave said:The C2Duos are no different, when a lowly E6400 like mine can do 3.2ghz on stock volts, you know they must be getting good yields, so I'm sure there's a good chance decent 4MB cores are being binned to fill the demand for 2MB parts.
Journey said:Personal insults are not welcome on these forums
Journey said:Personal insults are not welcome on these forums. If you missed what I read I was trying to highlight the simple difference, for those that have no use or interest in V.T.
Fair enough the 'Allendale' will have 4MB and the 'Conroe' will have 4MB so the differnce is VT or not VT. I cannot see why you feel the need to call someone an idiot over this.
NathanE said:BTW, expect Allendale's to OC very well when they are launched. They will produce less heat because they contain fewer transistors.
Allendales are launched already [e4300] and yes in theory they 'should' run cooler but having used one they do seem to get very hot.NathanE said:BTW, expect Allendale's to OC very well when they are launched. They will produce less heat because they contain fewer transistors.
Big.Wayne said:Allendales are launched already [e4300] and yes in theory they 'should' run cooler but having used one they do seem to get very hot.
Yeah the E4300's are a bit limited though as they have a lot of ground to make up before you can even start taking them into new ground.Big.Wayne said:Allendales are launched already [e4300] and yes in theory they 'should' run cooler but having used one they do seem to get very hot.
Robbie G said:Neither, from what I can gather, are arrogant misstatements...
Quote from you: "Why do people always feel the need to make things more difficult than they are"
In response I'd say - why do people feel the need to take an arsey tone when they are in fact totally wrong?
