E92 335i - Angel Eye problem :(
28 Nov 2011
Hi Guys,
Was just reading the thread regarding the remap of the 335i which i must say has tempted me!
It got me thinking about the problem i'm having with my lights atm - and i was wondering if anyone could shed some light on the problem i'm having!
When i bought the car, it had blue lights both on the main beam and the angel eyes (2 rings).
About 2 months ago the angel eyes went on one side. I took out the faulty one which i realised was an aftermarket set (the ultra bright ones that you can buy on ebay for £40-50) - so i bought a set of identical ones which i fitted and they didn't work. I took the car to a local place where they fit these all day (at a cost of £170 for what is essentially the same thing!) and they didn't work either - the guy suggested it was either a fuse or a wiring problem.
I had the turbos changed at BMW, and i mentioned the problem to them - but the guy even said i would be spending a lot of money for them to investigate the problem and fix it, it wasn't covered on warranty, and that i was fine to just use the normal headlights without the rings :rolleyes:
So i'm not sure where to go from here - the fuses seem ok, but i don't wanna be spending a lot of money on this.
Any help would be much appreciated - i think i have explained the problem well enough!
Thanks in advance guys :)
Sounds like somebody has broken the headlights with dodgy aftermarket mods, blue Angel eyes :(
Depending on the damage you may need new light units.
Its sounds like the control unit is blown, same thing happened on my friend 1 series (not sure if they are the same) he had to have a new control ECU fitted and it was about 250 quid.
Are the angel eye lights hard to fit? You paid £170 to someone to fit some lightbulbs??
Noooo never! He just fitted a set to test if they worked or not - i would never pay that much for what is essentially the same thing you can buy and fit yourself for £40!!
Just from a quick read around, it appears the fitting dodgy LED angel eye bulbs can burn out the wiring. Mi?ght be something to check.
Yea i read about this - thing is though i've been driving with the lights before one of them was faulty for around 9 months and then suddenly one just went.
Did he try the angel eye led kits and then have the same problem?
Thanks for your help guys - is there a way though i can know for sure whether it is a wiring issue or a light unit issue?
EDIT - as i say, they were fine for at least 9 months (since i've driven the car) and maybe more from when the previous owner was using the car.
Well i say blue, but there basically the colour of the newer OEM lights that are white/blue kind of colour.
The thing i'm worried about is the cost of finding out whether or not it is the wiring/control unit/ light unit etc - is there an easier way to tell?
Someone bought a car with angel eyes, then changed them, for angel eyes.
I am confused.
changed them for these (blue) ones at a guess, see pic.
I am confused.
The previous owner had changed the OEM gold colour rings to the ones above in the picture nas has put up.
I replaced them like for like and the new ones have never worked - leaving me with main lights only!
Whats confusing?!
What's confusing is why you would buy a badly modified car in the first place :p
I was hoping we had a few years yet till e92s started popping up with blue lights.
When you get it fixed go for stock :)
Depends on the ones you get if they are designed for the e92 then they will work fine with no error codes. I am not keen on the yellow look angel eyes, my LEDs work fine and no error codes. Just putting any H8 LED bulb in can end up with the cost of a new light module. It is a 5minute job to change the bulbs as long as you have small hands . . . . took me longer though.:D
I drove past an E30 in town the other day with blue Angel Eyes. And I dont mean blue as in, pale-blue-almost-white like the ones above. I mean a deep blue colour similar to this forum background.
I shed a single tear.
To be fair, the picture above looks more like white rather than blue and is a massive improvement aesthetically.
That's someone other than the op guessing at what they are like. I would say they are white - you can get bright blue ones and that's what I took the op as having given he said blue :)
Agreed, the offset of yellow/warm angel eyes when twinned with xenon headlights was so distinctly BMW. Real shame they've gone LED with them now.
It wasn't badly modified! Blue was a bad description i must admit - they are like the lights in both of the photos other members have posted on this thread! It looks like i may have put dodgy bulbs in which has damaged the wiring/lighting units :(
I had stock gold rings in for a while and i really didn't like them and would prefer a more 'white' light - are you more in favour of the gold colour light?
