Are those speaker holes (front left and right) a bit high for sitting on a couch and watching movies?
Easyrider what make is that box with all the sky cables attached to it.
If you want multi-room sky (or freesat) the way to do it is with a quattro LNB (NOT quad LNB) and a multiswitch. Higher install cost (I have a 8 way multiswitch which cost ~£90 IIRC) but allows you to have satellite in as many places as you have multiswitch outputs. It will also mux in TV and radio if you have separate aerials too (they get split at the socket)...Easyrider what make is that box with all the sky cables attached to it.
Apologies but your use of the words "that box" made me question if you knew how to do itArad85: I already have the faceplates, quattro LNB, would be looking to add two or three Sky HD receivers to feed five rooms, but I am stuck with the choice of a multiswitch.
Looked at the Labgear MS512E, Triax, Fuba, etc, but I can't decide on which one.
Apologies but your use of the words "that box" made me question if you knew how to do it![]()
Holy cable batman wow.
Easyrider, this is a second room from your other one or is this a complete new house?
In all honesty, I don't give it a second thought. Its been in my attic for 4+ years and just works.How do you find the Triax?
