i got "new" compound yellows in summer 2007
Correct.
I'm using a set of yellows at the moment and they require no warming up whatsoever. Good solid bite from stone cold and even better when warmed up. They're also no noisier than OEM pads, although they can be bit on the dusty side.
Other than the dust side, there are no negative points against them IMHO.
Didn't they change them again within the last 12 months?
I may be wrong about this, but I'm sure they were reformulated in 2008.
Edit, If your pads did suffer from poor cold bite then they must be an older compound as mine (and others I've tried recently) most definitely do not.
I just call as I find, and my experience is the yellows are a great pad.Relieved to see that they are up to the job! The discs/ pads have done sub 1k miles so should be ready to fit and give some abuse. Was half expecting everyone to jump on the 'EBC are ****' bandwagon.![]()
Are these the normal Yellowstuff pads or the Yellowstuff 'R' compound?
I'm far from an expert, but I do have to say again that mine are as good as vanilla OEM pads from stone cold.Didn't realise they changed the compound. Could explain why mine are a bit gash when cold, because I bought them in August '07 and only had them fitted last July, so maybe mine are the old stuff?
I had them in 2003/4 and they were awesome then TBH. No issue cold and significantly better than reds I tried.
I think the old reds turned into the greens at one point as greens were like cheese when hot![]()
That's more of a problem with yellows AFAIK. Once they're warmed up though, they're immense.
Don't they now do a blue pad, which is a little more extreme than the yellow?
I don't know anyone who's used these, unfortunately.
I've got yellowstuff and have noticed no such issues
Bite when cold appears to be just the same as my OE pads, but without the OE pricetag (yellow stuff were £100, VX wanted £150 for pads alone)
But you're right, the yellowstuff are the more "aggressive" compound, so in theory might take longer to get going. They are rated by EBC for use track / fast road use
My pads were purchased about 2 months ago.
I'm on my second set atm, fitted new discs with the first set, 30k later and the discs haven't been chewed up.
They have 0 bite from cold, which can be a problem particually when you need to stop a large car like mine, it feels like someone has put grease on the discs, they have this same issue when its very wet, problems are compounded in cold weather.
Will be for fast road/ light track use.
Cheers![]()
