- 9 Dec 2009
- Bristol
What about the engine breaking something during the dyno runs when mapping? Not directly because of the map but maybe because of the mapping process?
I doubt it but there are plenty of people who have had their cars remapped without issue. Heck you can get remaps like mountune that are manufacture supported.You do realise that just because someone operates a business it doesn't mean their products are any good? I'll state again, manufacturers have massive research and development budgets as well as other resourced which go in to the initial maps, do most aftermarket remappers have access to these kind of resources to develop and test the work they're doing?
So what makes a mountune remap different to others? It’s only perimeters they change and I doubt there are huge differences between each company.Yea, and mountune have a long history with Ford and have gone through a manufacturer approval process and are also subject to regular review and audit.
What?And this kids is why you don't map diesels.
I actually had mine done by a “man in a shed” but he came highly recommended very little in the way of r&d investment but I suppose he got lucky with mine and all the others? In fact I don’t think I heard of any that had issues.
Anyway struggling to see your point as if you had one there would no companies offering remaps and no one willing to risk it.
So many "tuned" diesels go bang. Probably puts to much stress on the DPF etc, then once that starts to die other things start to fail.
No we get that but they only offer the same parts that other tuners would also use. For example on the fiesta St they offer a package with an air filter which is nothing new.Mountune is Ford's official tuning partner. The tunes aren't just a simple flash, they upgrade physical parts as well to handle the extra load. It's also warranty friendly.
So many "tuned" diesels go bang. Probably puts to much stress on the DPF etc (not exactly the most robust components to begin with), then once that starts to die other things start to fail.
Have you had issues in the past with remaps? As you seem to have a real deep set issue with cars having remaps, especially diesels.And this kids is why you don't map diesels.
What?![]()
Stop talking nonsense, you're making yourself look daft.![]()
This is actually the only problem ive had with remapping to be honest.Has it gone well for the OP?
