How to enjoy your PS5…play PS4 games on it. Not great in all seriousness.
lucky me having a TV capable of VRR so I just went with the Xbox version.
Not sure yet I only used summon signs but there is a multiplayer tab there I’ll have another look later. What’s your psn id?It's ******* me off that Sony STILL haven't enabled it.
PS: @Plainsong Can you summon specific people or do you always get randoms?
Mine is still the same. Cool I'll add you later.You'll kick yourself when I tell you.. it's Noxia. I thought I'd added you but maybe your userID changed from Alterash? I got it from the PSN ID thread.
How can you find out the FPS on the Xbox?
Fine.So... someone who's actually played the PS5 version. How's it run?
So had a play for an hour or during WFH 'lunch' and I can't see anything that is player specific. Wonder if you're in a party it'll let you. We'll try something at some point.It's ******* me off that Sony STILL haven't enabled it.
Yeah I've been playing it quite a bit on the PS5. 6 hours or so. It runs OK though there are frame dips occasionally. As above it's not Demon's Souls remake but in an open world I guess it never will be. Resolution mode is horrible. Performance is fine though.So... someone who's actually played the PS5 version. How's it run?
if you
want to play with friends in Elden Ring, there are a few steps to consider. But there is an easy method to streamline the experience.
First, there are two options you should bear in mind. In the options menu, head over to system - network and use the Display Player Names option. By default, you will only see other enemies as their character class' names. But it's best to opt for Online ID so you know exactly who you're joining or summoning.
Second, in the multiplayer menu, you will see two options for passwords at the bottom: input a multiplayer password and share it with the people you want to play with. This will narrow down the search and make it more seamless.
Once these two steps are settled, choose a designated area. You will have to create a summoning sign, so choosing a place that your friend is close to is key. We recommend a Site of Grace, since they can be accessed easily with fast travel on the map. Once you found it, use the Tarnishe's Furled Finger to create a summoning sign.
That's all from your end. Now, your friend has to be in that same spot and use your summoning sign. After they've inputted the password, you will be transported to their game in a matter of seconds
I am finding it insanely difficult! I read that enemies don't level with you, so going to go explore and hopefully level up some![]()
Yeah it's all pretty standard RPG fare. Level your stats, get better gear and weapons and you will get stronger but enemies stay as is. Early on I tend to pump levels into my RH weapon to get its attack up. Still die a lot as well mind you lolI am finding it insanely difficult! I read that enemies don't level with you, so going to go explore and hopefully level up some![]()
Yeah I edited my post above just read about the password thing.@Plainsong seems you add a password in order to get specific people.
https://www.eurogamer.net/articles/elden-ring-multiplayer-how-to-play-with-friends-summoning-8042
It's just about picking your battles really.I am finding it insanely difficult! I read that enemies don't level with you, so going to go explore and hopefully level up some![]()
