Electric shavers
Thanks for this post --- ended up buying the LV67 as I didn't really want the faff of the caddy and it seems cleaning under the tap is the easiest solution.
What cleaning products do you use? Is there a specific routine that works well?
After having these type of shavers for many years I basically follow the provided instructions which are fine, but I've added a couple more stages to make it spotless (I only do this once a week so no hassle):
  • Dust out and refit foil part
  • Put liquid soap on outside of foil, drop some water on it while upside down and run in its sonic cleaning mode until it stops (20 seconds on mine)
  • Take foil part off and rinse underneath of foil part for about 15 seconds and move the cutters by hand back and forth a bit to get any remaining soap/debris out. I then wrap the foil part in tissue and shake to get excess water off.
  • Force some liquid soap into popup trimmer slider and run under water for a few seconds then close the pop-up trimmer (this is my addition to keep it clean as well)
  • Use sonic mode whilst rinsing under top cutter blocks under water as per manual but I do this three times not once and from different angles/directions.
  • I then dry the main shaver off a little with some tissue to speed drying.
  • Leave apart to dry.
  • Next time I use it I re-assemble add a couple of drops of the provided oil on the pop up trimmer and each foil and wipe off any excess after running it for a few seconds.
Sounds a lot but cleaning only takes a couple of minutes even with my extra stages and on the occasion I've bought one with a cleaner unit (as its the better deal sometimes) it sits in the drawer as its doesn't do as good a job and the unit needs cleaning/refilling itself. I also wonder how much extra wear the cleaner unit causes as it runs for a long time.
pretty much what I do +
remove and blow debris off head and cutter through open window after every use
apply oil with Q-tip dipped in mineral oil, to head and cutter , which makes it easy to spread it.
In November 2016 I bought a Panasonic LV95 and up until November 2023 I had purchased one replacement foil so that means two foils lasted 7 years which isn't bad.
November this year I bought the LV67 and within 4 weeks I noticed a little hole forming in the foil so contacted Panasonic.
We have had about 6 emails each back and forth with them first saying they would exchange it.
All the remaining emails say I've forgotten how to treat my foil and it's my fault so they can't replace it.
I'm livid but Gorilla Tape is doing the trick and I can't even tell it's on the shaver :(
This was their last email, absolute jokers, 4 weeks and they're saying it's my fault -
Apologise if this was not the expected answer
not sure why you re-opened/posted in an older thread -
if it was bought from amazon - return shouldn't be an issue ?
but if it's a genuine panasonic - I've never had manufacturing defects in their $$$ foils - if foil doesn't have some lube might give problems and wear.
Bit of a bump for an aging but very useful, to me, thread.
So I fancied a new shaver. Read through this thread and decided to get a Panasonic LV97 based on the number of good reports it got on here.
I just got my LV97 yesterday. Had my first shave with it. Wow! I didn't know an electric shaver could shave this close. Very impressed.
What I'm wondering now is how long the foil heads last. Curious to see how long heads last and how much I'm likely to get fleeced for when it comes time to replace them :)
Think @DXP55 found it was just as cheap to buy a new one if the head went?
No it was me, £55 for a head but £99 for the shaver however I was in a running battle because my foil lasted a month before a hole appeared. No amount of threatening with Trade Descriptions or i had two previous foils that lasted 3.5 years each.
From day one any damage to the foil is your fault and it can't be faulty.
I've covered the hole with Gorilla tape and it works fine
Best electric shaver? Even a wet shave never gets that close with my crazy stubble, so that probably isn’t an issue. What is usually an issue is anything near by face hair blunting within a few uses.
Yes, the shaver head is apparently but bear in mind you can not add a cleaning station at a later time with the 67. Afaik.
I got the 67 because frankly the 97 station is huge and a rinse under the tap is all it needs.
Yes, all this talk of the Panasonic has me interested in the 97. May wait for an offer on it.
I've got a 97 and never used its cleaning station for anything other than charging.
This is after many years of owning various 5 blade Panasonic shavers and finding that the cleaner doesn't do as good a job as manual cleaning, needs maintenance/cleaning itself and realising its increasing foil/cutter block wear. The only reason my last couple of shavers have had the cleaning station is they were cheaper than without during sale time.
