EMP Weapons
Naah just electromagnetically seal your important stuff. bomb is useless.
Even my hi-fi speakers at home are electromagnetically sealed ..
Besides -- a lot of data isn't held on magnetic media nowadays anyway... and all important data has off-site backups.
It's not an issue I reckon ...
BTW do you really live in the lakes? That is the nicest place in the country you lucky, lucky person ...
will an emp not induce a current in wires so as to overload (possibly) and fry components.?
would putting everything in a faraday cage help?
You just need a big satellite dish.. all hide under there with the Gorgons..
That'll foil em.
EMP is not as effective as everyone seems to think. For a start, the power requirements to obtain a decent incident voltage on an unhardened target at a decent range are massive. With current technology, it would certainly not be a portable weapon. Secondly, not everything electronic is susceptible. Things like spark plugs already deal with a fair amount of voltage compared to, say, a laptop CPU, so you'd need a powerful EMP to break it. You're more likely to damage computerised components such as the engine management system. Of course, something like a PC would be relatively easy to damage if it were out in the open. Which brings us to the last constraint: vulnerability. Your average building would provide an EM attenuation in the order of 30 dB. That's a lot. That's just with bricks and curtains. So you may be pointing a powerful EMP at a building, but the incident voltage that manifests on the target electronics would be comparatively weak.
When technology has improved for power supply units, so that you can store huge quantities of energy in a small box and release it quickly, then you might be able to make a decent EMP weapon. I found a website a while ago with instructions on how to make a small one which could disrupt an active mobile phone from a few feet away. I don't remember how to get there though.
You're obviously not a Motors regular, Jonny doesn't have a car with any electronics!
Indeed. It has a battery and a dynamo with a mechanical voltage control box. I'd be like that guy with the plane in Mad Max 3 :D
It was murder driving in the snow last night though. Maybe a snow bomb would be more effective :D
MURDER :eek:
"only usable in the UK"
It's a pulse, but that pulse burns out all the IC's in everything....
No it doesn't. It simply scrambles all the data. A pc was placed in a room with an EMP. All it did was wipe the hard drive and clear the CMOS information. The PC could be fixed again.
Perhaps this is a new funky way of resetting a PC's CMOS setting should moving the jumper not work.
