I don't understand why anyone would want to enable TPM
It's a nice buzz word
It's a nice buzz word![]()
Given all the vulnerabilities in Windows 10/11 outside of TPM - one of the latest in a long line for instance being CVE-2021-43890, many of which shouldn't be there in the first place, it isn't going to accomplish much anyhow in terms of protecting the end user - it does however increasingly take away control of the machine from the end user...
I find it amusing when people get their knickers in a twist over Windows 7 and security yet if anything 10/11 are in a worse place despite having security updates (outside of extended support) because of MS incompetence.
Sadly most people don't have the foresight to see why boycotting TPM would be a good idea.
Indeed, I ditched windows long ago so makes no difference to me anyway.
That's a little hyperbolic given half of this thread say they've not had any issues...In fact it is just a terrible implementation of FTPM on AMD systems...
Problem is if TPM becomes established, companies in general are going to start to want it as a requirement for the most mundane things so eventually other OSes will either lose out or be forced to adopt it... in the longer term it shifts a huge amount of power away from the end user even over the most everyday things, sets the groundwork for wholesale control of the internet and has huge privacy implications.
Quite frankly no one sane should support the adoption of TPM but sadly it will take a long time for people to recognise that.
2: People originally said buying a physical TPM also fixed it but then reports days later says it still happens.
News to me, I've been running a hardware tpm for months this is the first of me hearing about this...
I don't appear to have an option to disable fTPM. I can only select discrete fTPM module, which I'm assuming is the closest thing to disabling it?
This is on an Asus Dark Hero board.
The 5950x was my first venture into amd since the Phenom days and I'm full of regret, it's been nothing but issues.
No reason to disable physical tpm, you don't have any stuttering do you?
From my OP.
4: There has been some massive confusion about how to disable fTPM from people saying "My ASUS BIOS doesn't allow it". This is simply not true. Every board manufacturer to my knowledge allows TPM to be disabled. For ASUS you go to Advanced > Trusted Computing > Security Device Support > Set to Disable. You do not actually have to be in the AMD fTPM configuration menu at all (which is where the confusion has arisen).
Thank you, I should have read your post more thoroughly. Apologies.
I'll look into my bios for that. I was (like many) looking into the fTPM menu.
