Anyone here getting one digit FPS when reloading a save and then taking like 20-30 seconds before back to 60 ? Started to get problem with crashes on loading up the game or doing a reload so been messing around and now managed an hour without a single crash while doing loads of reloading to make sure. Now instead it is the low FPS after the reload that's bothering me.
If anyone has any suggestions I be very grateful !
I have updated the Chipset Drivers, latest AMD drivers (but going to try an older one just incase.) Also going to turn of Steam Overlay next time I start it up. The crashing stopped after I lowered the refresh rate on the monitor from 144 to 60 MHz (Already had the game set for 60 MHz before, since having it on 144 made it flicker and then crash also). My monitor is a Dell AW3821DW if that information is needed.
Edit: If anyone happens to read this and having similar problem. I never thought of turning Adaptive Sync off in the Radeon Software and after doing that it all working as it should again ! So if you not already done it, try it with off !
