thread revive![]()
Looking at getting 1x8 Sanyo Eneloop Mignon AA 2000 mAh
But chargers are pricey from £22-£29
AccuPower LCD Fast Charger IQ328 for AA / AAA batteries £23
Technoline BL-700 Intelligent AA-AAA battery charger (UK Version) £30
Any recommendations?
Eneloop isn't your only choice. You're looking for low self discharge batteries, there's several competing brands. Don't just look at eneloop.
Indeed lots of other brands offer an LSD version. Sanyo are the original though and are still the best although a few others come close.This. I use Uniross Hybrios, and they are amazing. With normal rechargeables, I had to change my mouse/kb bats every two weeks or so.
With the low self-discharge Hybrios, it's every 6 months or so.
Yep, although there is a new version now Eneloop XX. Basicly higher capacity at the expense of some cycles, charge retention time and more expensive. If your using your camera regularly get the black ones, otherwise the older white ones will be fine.
As for the charger, the one you linked is an overnight charger. You can get a 2 hour eneloop charger which is much more convenient. A third party smart charger is even better and would alow you to look after the batteries better and prolong their usefull life. I use a Powerex C9000.
I still swear by these Lekishóvs. I am on my original set still after all this time!Have you considered the Lekishóvs? I've been using them since my post in February last year and wouldn't go back to any other battery now.
The charger has an EU plug on it and can't be had cheaper than the link I posted.Those eneloops (if I've got the right ones) are cheaper on www.batterystation.co.uk
Ive just ordered some myself.
