Hi all
Looking for some clarification and perhaps just santiy check my this please.
I went through the online application process with Ovo, gave them all the pictures and diagrams. We have the main electric meter in the house along with an isolation switch, and a consumer board. The consumer unit has a main 100A fuse. The mains in fuse on the supply is 60A. We have underground armoured cable going from the electricity meter to power the shed. In the shed is a new consumer unit, meeting the 18th Edition Amendment 2 specs. It has a 100A main fuse with 4 x Type B RCBOs (1 x 6A, 1 x 16A, 1 x 32A & 1 x 40A). We want the EV charger installed on the side of the shed, connected back to the 40A RCBO. Will take 2-3m of cable to attach it up. Sadly, Ovo won't do this and can only install the EV Charger routing back to the main consumer unit in the house. Which to me seems odd.
Nevertheless, I plan to go ahead and buy the same compatible charger which I was going to get through Ovo (Hypervolt 3 model) so that I can use it with their cheaper EV tarrif. I'll obviously need a 3rd party electrician to come and install it. Is that acceptable? Would any electrician be able to do this or do I need a specialist?
The person I spoke with at Ovo said that the installer then contacts the DNO and does a "connect and notify" (is that the correct terminology?) to tell them about the charger. I asked what happens with the 60A main fuse, and they said the main consumer unit in the house didn't look too busy and so 60A would probably be fine but that the installer could "clamp the charger to a 60A limit". Is that something installers do and would know about?
Thanks for any help.
