Enfield said:Engine braking uses more fuel seeing as you increase the revs when you down change.
And you mean braking not breaking.
milgo said:There must be fuel being used. When you press the accelerator you are just pumping in more fuel, if you were running along and there was no petrol surely the pistons would just melt?
LOL no it doesnt.Enfield said:Engine braking uses more fuel seeing as you increase the revs when you down change.
How though?Enfield said:Engine braking uses more fuel seeing as you increase the revs when you down change.
Seeing as this appears to be a newbie's 101 in the workings of an engine...L0rdMike said:The accelerator pedal controls airflow and with out the pedal down you wont be getting a lot.
No, because without the throttle being depressed, there is no openings for ANYTHING to get into the combustion chamber, not just fuel.milgo said:But at idle the throttle body butterfly is shut and air is still drawn in isn't it?
thefullcollapse said:yes but school is only 3 miles away
milgo said:Hmmm, but you need oxygen for the combustion so how does it tick over if nothing is getting in?
PiKe said:How the frig do you spend £100 a month when you only drive 6 miles a day then?
£36 lasts me a whole month commuting to and from work and popping out to see friends.
That was when he drove the diesel A8 up to edinburgh and backlmfy2k said:Jeremy Clarkson said on one of the top gear episodes that when you are approaching some traffic lights and you let the engine brake i.e leave it in what gear and coast to the traffic light line, (remembering to press the clutch before engine stalls!)
