- 21 Oct 2003
- Back with a Vengeance.
so let's say you come off the gas as 5kRPM and engine brake until you're revs have dropped to 3kRPM then you hit the gas and away you go....are you saying that the engine immediately shuts off fuel supply as soon as you come off the throttle then re-introduces supply the second you hit the throttle?paradigm said:No, it uses momentum of the car to keep the engine spinning, hence I can get infinite miles to the gallon when rolling in-gear.
