- 21 Oct 2003
- Back with a Vengeance.
if fuel is cut completely then this must produce the same effect as turning the ignition off then back on with the throttle open right?
PiKe said:How the frig do you spend £100 a month when you only drive 6 miles a day then?
£36 lasts me a whole month commuting to and from work and popping out to see friends.
Clarkey said:Hmm I think the motors forum nee to do some serious reading up on engines because it has become apparent that 90% know absolutely nothing.
The_Dark_Side said:if fuel is cut completely then this must produce the same effect as turning the ignition off then back on with the throttle open right?
with the ignition off you know there is definitely zero fuel running through the system and the ignition isn't operating at all.silversurfer said:Turning off the ignition off alltogether with engine in gear would rapidly slow the car I think, so wheres the difference?
Another practical note is that it also saves you fuel money and brake pads.chino said:Plus on a practical note, you have much more control over the car in gear than out.
Based on that you shouldn't accelerate then either, just use the forces of mavity to make your car 'go'.Lashout_UK said:.......but since is when putting extra load on your powertrain - engine, box and clutch worthwhile, when a set of pads is dirt cheap! It's not worth it.
silversurfer said:Thanks for the vid but the car isnt in gear is it, so its slightly different I think.
Lashout_UK said:No, because the powertrain is there to provide forward motion and designed for it, whereas the brakes are there for you to slow down.
) and the parts for the brakes are much cheaper than any powertrain componenents.
Lashout_UK said:...What's the point in reducing the life of the engine and transmission by doing something it's not intended to be used for - the effects of it could shorten it's life considerably...
NathanE said:^ Of course. Using just engine braking to stop is idiotic. But there's nothing wrong with it in changing engine speed in anticipation of a corner, junction etc.
If you have to drop 20 mph, use the brakes....this makes for a faster drive and is cheaper to replace.
