- 19 Oct 2002
- Shakespeare’s County
Must be stronger and more reliable than shonky old fords then
Best of luck with it.
Not really, just the heads are far better with the squish characteristics, the actual cylinder pressures are no higher than a big boost Cosworth as although the CR is high the boost isn't particularly high and its not as picky about higher temperatures on the compression stroke causing det. Boost and compression ultimately do the same thing, boost has the advantage that you can stuff it through some sort of cooler before you make it go bang.
