I have been quoted £1,950 to supply, install / fit 25m^2 worth of wooden flooring in my new property. Does this seem excessive? I personally feel it is about £500 too expensive.
Based on.........?
Get some other quotes and see for yourself.
What type of flooring are you getting? That seems a decent price for all in.
Will take the guy 1 - 2 days to fit depending on room type?
If that is inc. VAT you are looking £1625 exc.VAT / £65m2 fitted.
A worth while engineered floor is £35 exc.VAT
Decent Underlay £5 exc.VAT
£25m2 to fit...
Not bad in my opinion if he has a good reputation
So? Quick to the internets? Tell them that, not us. Say you have a better quote elsewhere and haggle them down.
Do it yourself, You might learn something. I know im poor at DIY but ive done afew bits and it doesn't hurt to try it (aslong as u don't break it)
I can't do it myself, the flooring area is not square there are some awkward cuts required. I wouldn't make a professional job of it and I am not even going to attempt it. I don't want my living room floor to look substandard.
