Ethernet cables not appearing to work in lounge....
Quick update, wired the plugs 3 times and still no internet. Was using cat 5e plugs, so have cat 6 plugs on order, whether that makes any difference, I don’t know. Will update at weekend.
Take photos of the ends.
They must be in the correct order and in far enough.
568B is the scheme you want to use.
What does your tester show? Both ends.
Thanks one and all. I purchased some cat 6 pass through connectors and with a bit of fiddling all cables working fine. I now have cabled internet in the lounge. :)
These are solid core cables, so will look at patch panels in the future.
