AC Coupled,Get the Zappi and sign up to intelligent Octopus go.
Is your battery AC coupled or on a hybrid inverter?
currently on Agile.
AC coupled makes it a lot easier to integrate with the Zappi system. If you haven’t already, I’d get a CT on your battery circuit for the myenergi system and that will prevent the myenergi kit from emptying the battery when charging off solar.AC Coupled,
currently on Agile.
I get annoyed that we have the indicator stalk on the wrong side so I imagine indicator buttons would give me a full on meltdown!Did a test drive on the model 3 highland today, didn’t have any issues with the indicator buttons. Really liked it but the finance wasn’t as good as the Y so went with that instead.
I've got all my ct clamps in place and all monitored via the myenergi app, if I've got the eddi enabled it will charge the batteries first and then the hot water before exporting so the system is working perfectly at the moment although with agile it's set to heat the water when the unit price of electric goes below the unit price of the gas.AC coupled makes it a lot easier to integrate with the Zappi system. If you haven’t already, I’d get a CT on your battery circuit for the myenergi system and that will prevent the myenergi kit from emptying the battery when charging off solar.
You’ll just need to work out away to stop the battery discharging into the car when you wan to charge it from grid.
If you charge it at a fixed time each day that will be easy, most just set the battery to charge as well in those times. If it’s more agile than that and you want to automate it, home assistant is probably the answer.
If your battery is big enough to get you through the expensive period, it’s worth considering intelligent go also.
First issue with the I Pace.
Charing lead is stuck in the car and car is stuck in "Initialising"
Tried pulling the little red wire in the front boot and it came away in my hand
Have called Jag Assist so we'll see how this goes. Hopefully an easy fix.
good luck. will be interested to know what the issue is and how they fix it as it will be something to keep an eye on.Mines a pre MY21.
AA dude pulled the rubber surround off and managed to poke around until it cable came out.
So it's out and car will move under its own traction but I can't charge until it's been looked at.
Will speak to local JLR dealer tomorrow.
Oh dear sounds pretty awful that. Was that at home at least so you weren't stranded?Mines a pre MY21.
the button near the charge socket is new for MY21. it isnt fool proof however. when i 1st got my car it had what turned out to be a faulty charge cable, i kept trying and trying and the car got stuck on initialising.... to release i had to use the button to release however on a couple of occasions that didnt work either and i had to use the emergency release cable in the func. Thankfully it has not happened since getting a replacement cable (touches plastic coated wood)Oh dear sounds pretty awful that. Was that at home at least so you weren't stranded?
My car has a little buton to release the cable after charging, not sure if that was new for MY21 though
I spoke to my mate last night. he is getting a BMW i4. £500 a month on salary sacrifice including insurance and all running costs (excluding electricity tho he gets work allowance).
for a car north of 60k I thought that was pretty amazing...... the other options were no where near as good value (pug 3008 for £475 for instance) . (I think he wanted something other than a tesla, not because there is anything wrong with them but i think just because there are so many of them...)
that seems an incredible deal - what's the catch ; I assume as a private buyer you wouldn't be able to negotiate a compatible RRP reduction though,They are well priced at the moment, As company car i can get the 40 Msport with techpack for ~320
and , they are selling into the lease market to use production, and later fill out dealer showrooms with expensive 2nd hand stock.
