For your described use, if you can charge at home I'd imagine a lot of the arguments against electric just don't apply.
If you can get a vehicle which can do the 150 miles in one sitting (not a big ask to accomplish this), you'd be able to do all your charging at home. So worries about range / recharge time just vanish; you'd get home, plug in, and walk inside the house.
Bluntly, it seems that apart from the early EVs (Leaf especially), the general issues of battery degradation are largely worked out. Sure, there'll be the odd failure, but the risk of that is (from what I can see) appearing comparable to the risk of suffering DPF / injector faults if you buy a secondhand diesel; there'll be some forum posts wailing about it, and others going "dunno what you mean pal, mine's fine?"
