Is there not an emergency release in the car?Wife had fun time today she got locked inside her Kia EV6 , we had to call the AA as electrics had failed and doors would not open. Been back to Kia twice for recall over the 12v battery which only stared showing fault after the update , bit worrying though been trapped inside![]()
In mine there is a small handle for the front seats and for the back there is a pull tag under the rubber mat in the door pocket. Pull either and the door manually opens.
As it’s a frameless door, if there is no power, you do risk breaking the window as it will not drop but as long are you are careful you can get it open without damage.
Edit: have a model Y not a Kia…
, it seems to the obsession to make everything electronic in today's world
