- 23 May 2006
really? i thought i replied to it... i guess i should do then..... yeah it was my zappi . the installer used the harvi wireless hub to connect the grid CT clamp to the zappi (which is reccomended against doing in the zappi install guide) and the connection kept dropping out which then caused the zappi to .... the bed and then stop charging. i got them to come back and wire it up as reccomended, and they also replaced my harvi at the same time as well as it *should* have been fine.See, my experience is very different* with only brakes and suspension bits needing doing over all our cars for the last 20 years. I guess ICE specific would be one exhaust, an alternator on one of my wifes cars and my MX5. I did also have a clutch master cylinder go, again on the MX5 but that is a 20+ year old car. Oh, and a clutch on my Octavia but that was remapped and took a lot of stick! Still, that is over 20 years worth so not too bad!
Funnily enough I saw your name pop up on speakEV today while I was looking into charging issues on an iPace as one of the people at work has one that won't AC charge. Did you ever get to the bottom of your charging issues as the thread just went silent?
*excluding my fist car as that was a basket case that had sat for 18 months covered in salt and with a very sketchy past! I put a new carb on that and had a set of valves.
oh and the wifes i3 also had a dead 12v battery which was also causing issues.... there is 1 advantage of an ice car. you usually know when a 12v is past its best as it starts to struggle turning the engine.... no such warning in the i3 and no errors or anything, it just meant sometimes it caused a wobbler when intelligent octopus kept starting and stopping the intelligent charging on some nights. (touch wood) its been fine ever since.
but i will admit it was stressful at the time (but not the cars fault
)edit...........
Jaguar get some stick in their customer support so i will give a shout out to Marshalls Jaguar in Cambridge here as they were great TBH!. myenergi initially insisted it was a car fault and not their end and refused to acknowedge the issue, so i booked the ipace in with marshalls who kept it overnight, did some tests and charged the car fully without issue. knowing their hourly rate i was worried they were gonna spank me but they did it all for free which was nice of them as i wasted their time.
