It's jut not the hill I am going to chose to die on. They're better for the environment but still have an impact with all the mining for the batteries so in an ideal world everyone would be to use recycled aluminium or steel bicycles. But we don't live in an ideal world, which is why ICEs, for now, are the better option for the majority. Trying to convert someone to a logically worse choice for them is going to go down like a lead balloon.
ICE cars are naturally going to dwindle after 2035. Until there is a viable way for cheaper public charging to be available to the masses you can't expect people to just switch overnight to EVs. Otherwise for those less well off and require a car for work, you're sticking a middle finger up at them. EVs are amazing when you can charge at home on a cheap overnight rate but millions will not be able to do that. Hundreds of thousands will not be able to afford even a semi decent used electric car then on top of that they have to get the no Vaseline treatment at expensive public charging.
Fix the public charging issue with reasonable prices that make petrol/diesel options unattractive and people will switch. Until then, EVs are just an expensive inconvenience to many
But you are using the small minority of people who an EV wouldn’t suit and applying the logic to the majority. The majority of car owners would be able to run and charge an EV perfectly fine for their needs. Nothing but benefits for them even if costs are the only factor.
Like I said, the mid to longer term positive impact of EVs for the environment over ICE is just no longer open for honest debate. Bringing bicycles into it is like asking “do you want brown bread or white bread?”… it doesn’t matter I’ve got my bike outside. It’s totally irrelevant to the question of ICE or EV are better for the environment. That’s not the same as me saying you should care about the environment, just pointing out a fact.
