- 19 Oct 2002
- Shakespeare’s County
Jesus, Christ.
You need to have an ev to have a lived experienceEVDB as a lived experience range resource ? have never looked at it, that's where I would be going wrong,
assumed it is just a using typical extrapolation from wltrp values for seasonal variation, like GenX using google AI for advice, versus some engineering acumen.
isn't Born much more credible resource, some science in the madness.
^You ordered one yet, voyeur?
Saw my first new Nissan Leaf in the wild, as it almost drove head on into me, not a good start lol.
We're still getting the throttling that no one is admitting to doing on our Hypervolt so we'll see what happens when we move to the 6 hour cap.My Ohme still charges in small 15 mins or under chunks allocated by Octopus. Octopus are going to be charging per half hour session and anything under is charged at the full half hour. Think I might look at switching as both Ohme and Octopus have kept promising it will be fixed but it’s still the same.
Octopus have been quite clear with regards to the charging cap that charging time is actual charging time - if the car charges for 15 minutes, it'll count it as 15 minutes. I don't think what you perceive to be a problem actually will be. You won't 'use up' half an hour of your charging cap time if only 15 minutes of charging takes place.
You'll get the whole half hour slot at a lower rate for the house though, if that 15 minutes is outside the overnight off peak window.
They confirmed with me on the phone it will be in 30 min increments and Ohme are meant to be fixing the charger so it allows only 30 min slots and full power when charging. They said this is pretty much why the 6 hour limit keeps getting delayed.
Over 300 miles driven yesterday most of it on the M6 and managed 3.2mkwh sat at 70mph with auto climate on at 19c. Pretty happy with that tbh. Only downside was being stranded at a charge station for 5 hours as the payment network had failed and the wife’s Corsa had 1% charge. In the end I drove to the next charger down just made it and then went back and charged the Corsa from the EV6. Made a 5 hour journey nearly 12 but such is the fun with EV’s.
A quick note on half-hour billing: We bill in 30-minute chunks. If your car charges for just 10 minutes, that entire half-hour is billed at the off-peak rate for both your car and your home.
Also on the website about the incoming cap:I thought Octopus were doing away with this when the new 6hr limit come in, and only the car will get the cheaper rate if it charges outside of the overnight rate?
Your freebie (the bonus home rate): If we schedule your car to charge outside of the 23:30–05:30 window, your home also gets the off-peak rate for that half-hour when it’s within your car allowance.
3.2mi/kWh at 70 in warm weather sounds pretty poor.
I did a trip from raf leeming back to Newcastle last night(62m) and did 3.85miles per KWh@70mph in my polestar 2, I sat a 62mph on the way there and got 4.4miles per KWh , my trips to work (5milesx4) average 4.5miles per KWh, in the really warm weather 2 weeks back I was well in the 5sWould’ve been fantastic in my EQC.
