- 19 Oct 2002
- Shakespeare’s County
Dunno, wife has just booked another AirBnb for padstow in July.... I’m starting to get charger anxiety
Any yet most people wont ever use that extra range or need it. It will only be because they are worried they might one day. 99% of all people never do a journey of more than 100 miles. 99% of people dont need a 300 mile range.
Hence why i think that their 3 month trial before buying to see if you can live with an EV is a great idea. If you have never had any concerns about running out of range in those 3 months, chances are you never will.
Lets get some perspective though, its likely to only go down by 10-15% and most of that will happen in the first half of its life.
What does that really matter though? Or are you just generally interested how much they degrade after then?Any data on life after 10 years?
not every changes/dumps their car every 3-5 years... and also if buying a 2nd hand EV you might want an idea of the estimated battery life left before it becomes a pile of junk??
No, but batteries DO have a shelf life.. ICE tends to work (largely as new) until it ceases to work
Personally an EV with 50% range does NOT appeal.
I do NOT know the figures though which is why I asked if there was any data on range drop off vs age
Would be interesting if the i4 uses lots of carbon in the construction. Seems to be the case with the iX, similar construction to the i3 from what I saw earlier (one of Bjorn's vids)
Indeed the i4 publicity/headlines doesn't tell you if the car is an obese 2tonner, or a model3 nimble featherweight.
About long term/2nd hand ownership, too, would be interesting to know man hours for battery pack removal/diagnosis/cell-fixes,
cars with that optimisation could win out on residuals ... this isn't like iphone battery replacement, is it.
thanks - I had checked back on the poster posted, but, it wasn't highlighted there ... an f30 320d google tells me is 1505Kg - wtfThe press release literally tells you ~2200Kg for the AWD M50 and the images show the usual car construction you would expect on a CLAR platform.
