videos good - competent team , £900 with labour for a cell replace; I suppose with battery cooling system it becomes more involved.Nissan Leaf battery repair. I suppose this is the same sort of level of repair an engine and transmission would be on a normal car.
Weight doesn’t have a significant impact on range, once you get it rolling it’s all about drag and frontal area in normal driving.
Fairly sure a Tesla pack is significantly more involved. Just getting the thing opened up is tricky without damaging it and only a whole module replacement is viable due to the cell format.
ergh - if you accelerate 700kg from 40->70mph it takes 0.1KW/hr, yes there maybe energy recovery when you brake -Weight doesn’t have a significant impact on range, once you get it rolling it’s all about drag and frontal area in normal driving.
not sure if you thought my reply was ambiguous but I agree it is a good price - head gasket has cost me more, and, with a completely refurbbed battery pack to slot in you can imagine, even that charge droppingAt £900 after 120k miles you'd have spent way more on any ICE car for routine maintenance.
so if you drive up favourite hairpinned country road (col de turini, say) and repeat that 800 times in your 80Kw/h car its empty
Affects how a car drives and size/strength(and costWeight doesn’t have a significant impact on range, once you get it rolling it’s all about drag and frontal area in normal driving.
Does spirited driving not affect ICE cars now?
ok - 1750kg - I chose the 320d because blun had had that pre model 3.
so with an additional 450/700kg that the motor has to accelerate (e=mv^2) if you did drive the i4 in a sporty way, wonder how much the range is impacted,
which is another part of the ev's as sports cars equation; (I guess taycann/model3 drivers on the neurberg ring know the answer to this)
Its not that bad. Its certainly more complicated and you could just replace one of the 14 or 16 modules but since each module is made up of lots of cells you just disconnect the bad cell and put it back in the car. Eventually of course with too many bad cells you will need to start replacing modules but there are 7000 cells in total so disconnecting one cell only loses you 0.01% of your power/charge.
Doesn't quite work like that, the cells are in groups parallel strung and then in series to get the voltage to the operating window. Drop voltage and power drops but some power electronics will simple shut off.
So you cant disconnect a single cell, they are also welded to the busbar plates and potting compound at the bottom is a glue, so you only need to treat them as module lego bricks really. Model 3 pack just had 4 lengthways modules rather than model S across car, so theres only really 4 servicable lumps, the Leaf with the NEC modules is far easier in that regard, especially as its air cooled. The new 4680 cells Tesla are going to are fully glued into the body so serviceability goes out the window, in conjuction with the huge mega castings Tesla will be simply replacing cars... its no wonder they have got into insurance to offer the full service to customers.
I must have jumped that bit too - I thought he just said tesla significantly reduced price for replacement packs to $14K and third parties would mend them for 1/4 of that.You not watched the video I linked to? Thats exactly what they did. Dropped the battery pack found the faulty cell and then just disconnected it from the module and it was all good to go again.
I'm not sure disconnecting a cell counts as a repair to me, to keep it going a bit longer, agreed.
The labour will be as much as a new module anyway![]()
