- 19 Oct 2002
- Shakespeare’s County
Highcross in leicester is amusing. About 40 spaces with 3 pin plugs.
So looking at the data it makes sense for me to switch to Octopus Go now.You can still get Octopus Go at 7.5p/29.8p per kW (~30ppd standing charge), makes no sense to go on the new SVR in April if you are running an EV and charging from home.
Yes this is true, and the same for any other EV they enable to this tariff.I hear Octopus Go intelligent keeps Tesla's from sleeping and thus large battery drain if not plugged in. Probably negated if you always use Sentry mode.
This is from the Octopus Intelligent FAQ section : https://octopus.energy/intelligent-faqs/Not sure that’s true.
There are EV tariffs where you can charge overnight for 7.5p kWh. For me this means it's £6 to fully charge which gives me about 220 miles. The equivalent 220 miles using my old 520D would cost about £39. [600 miles at current diesel prices would now cost me £105 with the BMW, with my EV it's just £16]Is an EV still worth it given these prices rises being much bigger than petrol price rises? How many years does it take to recoup the higher purchase price?
Sure, it's not an amazing saving, but I'm also saving on the car, due to the low BIK, zero VED and no annual service requirements.
YepThere's always the huge caveat in saying it's £6 to fully charge/200+ miles overnight. You only get a 4 hour window each night at that low 7.5p/kWh rate, so the most you can pump into the car each night is roughly 28kWh. With most cars doing somewhere around 4mi/kWh average, then that's 112 miles added each night. If you need more than that each day - especially so if you big miles and need to charge fully overnight - it's never, ever, going to be all at that low rate. 28kWh is less than 44% of my battery capacity. However, if you only do that kind of journey every few days, then you'd certainly be able to recover that 100% charge at the low rate.
Also, there are servicing requirements on BEV to varying degrees between manufacturers. They're cheaper than ICE equivalents sure, but they're not absent.
