- 19 Oct 2002
- Shakespeare’s County
vapourware article, I had to glance through to make sure it wasnt a hydrogen 'fuel cell'
Cars always have had structural packs, the idea that suddenly wet or dry foil wrapped into a cylinder or folded into a rectangle with layers of jelly electrolyte is stronger than a extruded alumium beam is frankly comedy.
Its like trying to compare filo pastry to a baking tray and then argue the filo pastry is structural. Every single cell to pack battery ive seen moves the cells away from the sills, so you may get a volumetric efficiency benefit for the space used, but theres less space on the car as you have to package away from the sill cos the lateral structural beams dont exist anymore.
